Bobodopalus
mx2 control with modbus
Hi all
im back to trying to get my inverter to work but this time with modbus, from this post http://forums.mrplc.com/index.php?/topic/38445-controlling-mx2-inverter-without-modbus/
and im stumped, im sure its just one thing somewhere messing it up
i have a cp1l-el20 with a cp1w-cif11 and a 3g3mx2 inverter and am attempting to control it via modbus, it is wired up as follows, sp+ to RDB+, sn- to RDA-, common to the plc pin and plc output pin 100.00 to logic input 1.
im using 100.00 to put it into run mode
the paremeters ive put in are a1=3,a2=1, a4=50, c070=3, c071=5,c072=1, c074=00, c075=1, b27=1.
im using MOV to set my speed to d1001
attached is my inv002_refresh x31 fb
thanks to any1 who can see my silly mistake
Edited by Bobodopalus
added info
getting back on it this morning, i just set the error FB locations up and im constantly getting a busy flag
just to add to this, ive been on the phone with omron for a long time changed the scanlist to #2 but still no luck, the person at omron had a go with my code with no luck until he changed the data area to W however when i applied this still no luck
for anyone who finds this in the future, it eventually worked, i think it was clearing the settings which got it working in the end
Congrats mate! You didn't give up. Can you enlighten us how you got it working after initial problems?
omron support got it to work by changing the area id to W instead of D as well as changing the MOV to the new W address, for whatever reason that fixed it, he wasn't too sure why
Hi All,
I want to control MX2 Inverter with basic Modbus commands (32300...).
Read holding registers and write frequency works nicely.
I have a problem with the start / forward/ reverse / stop commands.
32300:1 , 32301:5 , 32302:4 , 35303:0001 (coil-hex), 35304:1 (run command)
MX2 manual  page 307
Please give me some information regard to this!
