Posted 28 Mar 2020 Hi everyone, first time posting here. I've got a problem with the Modbus MTCP-CP1L-Server fonction block. it worked fine for a good amount of time until i try to change an ethernet switch (not managed) on my network. at this moment the fonction block started to give me an error code (2211 ''unit is busy, can't execute''). So i put the old switch back again and I called Omron and they tell me to download Etherway and try to send some data to it but they can't do more. I did and BAM, it worked again. everything was fine for about a week and i was like, okay if etherway can ''solve my problem with the fonction block, i can put the new switch again, No I can't. It give me the same error, I try'd so many thing( put the old switch, everything that was possible in Etherway, change IP address, ethernet setting, reboot everything, connecting the unit direct to my PC. nothing can erase that error. Unit is an CP1L-EM with built-in Ethernet port did someone had have the same problem, or have any idea that can help me ? thank. Sorry for my poor English, its not my first language. Share this post Link to post Share on other sites
