Posted 25 Mar 2020 Olá. Alguém poderia me dizer se existe adaptador rs485 ou rs232 para porta peripheral do cv1000 Share this post Link to post Share on other sites
Posted 25 Mar 2020 3 hours ago, ATAIDE said: Olá. Alguém poderia me dizer se existe adaptador rs485 ou rs232 para porta peripheral do cv1000 Google Translate: "Hello. Could someone tell me if there is rs485 or rs232 adapter for cv1000 peripheral port" Omron makes a ToolBus adaptor but I don't know that it will work with the CV series. I know there are forum members here that can confirm this. It looks like you have an empty Slot 00. You could try to find a Host Link Unit that will get you both RS232C and RS485. Share this post Link to post Share on other sites
Posted 25 Mar 2020 There is a cable CV500-CIF01. It is a 25 pin serial connector on the PC side that can be adapted to a 9 pin with a standard 25-9 adapter and then you can connect it to a serial to USB adapter. They are probably hard to find and probably expensive. Taking a quick look, there seem to be many third party replacement units that someone (not Omron) has designed that are USB, or 9 pin connectors. These might work, but the original will have the 25 pin connector. Share this post Link to post Share on other sites
Posted 25 Mar 2020 8 minutes ago, Michael Walsh said: There is a cable CV500-CIF01. Just for clarification, isn't this cable used for a PC with CX Programmer to talk ToolBus? If he wanted to connect, for example, a barcode scanner in No Protocol mode, wouldn't he need a Host Link unit? It's been a while since I've worked with a CV. Maybe the last time I was in jail. 1 person likes this Share this post Link to post Share on other sites
Posted 25 Mar 2020 Yes, that is correct. I have had to correct my son many times when he told people that "My Dad has been to jail".... no son, your Dad went to work in a jail.... 1 person likes this Share this post Link to post Share on other sites
Posted 22 Sep 2020 Olá, alguém teria datasheet porta periférica deste clp, comprei conector periférico e queria montar ele com uma saida db9 para comunicar com supervisório Share this post Link to post Share on other sites
