Posted 24 Feb 2020 11 hours ago, NevergoldMel said: Honestly, This sounds like a typo. I'd retype everything into the config. 11 hours ago, NevergoldMel said: Can Honestly, This sounds like a typo. I'd retype everything into the config. Hello mr.@NevergoldMel. Can you show me example? How to configuration master and 2 slave Qj71mt91 ? đđđ Share this post Link to post Share on other sites
Posted 25 Feb 2020 On 2/24/2020 at 4:29 AM, Djoko said: Hello mr.@NevergoldMel. Can you show me example? How to configuration master and 2 slave Qj71mt91 ? đđđ Why don't you screencapture your settings so we can check it. Â Share this post Link to post Share on other sites
Posted 27 Feb 2020 (edited) On 25/02/2020 at 7:14 PM, Gambit said: Why don't you screencapture your settings so we can check it. Â On 25/02/2020 at 7:14 PM, Gambit said: Why don't you screencapture your settings so we can check it. Â Â Â Â Edited 27 Feb 2020 by Djoko Share this post Link to post Share on other sites
Posted 27 Feb 2020 On 25/02/2020 at 7:14 PM, Gambit said: Why don't you screencapture your settings so we can check it. Â only slave 1 and slave 2 are configured by distinguishing the ip address.Other parameter not set Share this post Link to post Share on other sites
Posted 28 Feb 2020 looks ok is there any other equipment on the network ? Â Share this post Link to post Share on other sites
Posted 29 Feb 2020 On 28/02/2020 at 7:18 PM, Gambit said: looks ok is there any other equipment on the network ?  On 25/02/2020 at 7:14 PM, Gambit said: Why don't you screencapture your settings so we can check it.   On 28/02/2020 at 7:18 PM, Gambit said: looks ok is there any other equipment on the network ?  there are no other devices connected to the switch, only the laptop and 3 modbus are installed, but when the master and the first slave are working, the second slave cannot  pinging , after being removed from the switch and  installed directly into QJ71 without the hub being connected Share this post Link to post Share on other sites
Posted 2 Mar 2020 But it does ping if the master is not comm with slave 1? Â Share this post Link to post Share on other sites
Posted 3 Mar 2020 (edited) On 25/02/2020 at 7:14 PM, Gambit said: Why don't you screencapture your settings so we can check it.   On 28/02/2020 at 7:18 PM, Gambit said: looks ok is there any other equipment on the network ?  there are no other devices connected to the switch, only a notebook and 3 modbus installed Edited 3 Mar 2020 by Djoko Wrong sentences Share this post Link to post Share on other sites
Posted 3 Mar 2020 22 hours ago, Gambit said: But it does ping if the master is not comm with slave 1?  22 hours ago, Gambit said: But it does ping if the master is not comm with slave 1?  if the master and slave 1are stopped, Slave 2 can be ping and success  On 25/02/2020 at 7:14 PM, Gambit said:   On 28/02/2020 at 7:18 PM, Gambit said:   there are no other devices connected to , only a notebook and 3 modbus installed Share this post Link to post Share on other sites
Posted 3 Mar 2020 22 hours ago, Gambit said: But it does ping if the master is not comm with slave 1?  On 25/02/2020 at 7:14 PM, Gambit said:   On 28/02/2020 at 7:18 PM, Gambit said:   If Master and slave 1 are connected ,slave 2 cannot pinging,sometimes it can be connected, after 12 times time out Share this post Link to post Share on other sites
Posted 3 Mar 2020 You also do not have the CPU's connected on the ethernet ? Share this post Link to post Share on other sites
Posted 3 Mar 2020 1 hour ago, Gambit said: You also do not have the CPU's connected on the ethernet ? Yes,All cpu are connect to the switch ( hub ) On 25/02/2020 at 7:14 PM, Gambit said:   On 28/02/2020 at 7:18 PM, Gambit said:   there are no other devices connected to , only a notebook and 3 modbus installed Share this post Link to post Share on other sites
Posted 3 Mar 2020 What are the IP adressen of the CPU's. Have you tried removing the CPU from the network. Share this post Link to post Share on other sites
Posted 3 Mar 2020 4 hours ago, Gambit said: What are the IP adressen of the CPU's. Have you tried removing the CPU from the network. Master . Cpu IP = 192.168.3.30. QJ71MT91 IP = 192.168.3.40 SLAVE 1. CPU IP = 192.168.3.50. QJ71MT91 IP = 192.168.3.60. SLAVE 2. CPU ( Q02 H CPU ). QJ71 MT91 = 192.168.3 70 I've tried it, without a CPU connection to Ethernet,But still problem Share this post Link to post Share on other sites
Posted 4 Jul 2020 On 03/03/2020 at 8:34 PM, Djoko said: Master . Cpu IP = 192.168.3.30. QJ71MT91 IP = 192.168.3.40 SLAVE 1. CPU IP = 192.168.3.50. QJ71MT91 IP = 192.168.3.60. SLAVE 2. CPU ( Q02 H CPU ). QJ71 MT91 = 192.168.3 70 I've tried it, without a CPU connection to Ethernet,But still Until now my problem about Qj71mt91 has not been resolved and I have contacted a technician from the Mitsubishi agent but it has not been resolved either đđđ Share this post Link to post Share on other sites
Posted 7 Jul 2020 The only thing i can think of which should be not possible is that you have devices with the same MAC adress. Â Â Share this post Link to post Share on other sites
