Posted 10 Feb 2020 Hi, I am new in working with Omron PLC. I would like to know if there is a way to simulate an OMRON FINS SERVER to test a desktop application for simple command like READ_MEMORY_AREA, READ_CLOCK... I try to use CX-simulator but i'dont know how to connect it to my application. Thank you for your advice. Share this post Link to post Share on other sites
Posted 11 Feb 2020 Wouldn't know for sure, but I think there are two good Omron manuals, maybe there is a solution, one is called if i could remember, constructions of networks and other is construction of applications. I've found file names: W421_E1_02_CS1W_CJ1W_ETN21_Contrustion_of_Applications_Operation_Manual.pdf W420-E1-06_Cx1W-ETN21_Construction_of_Networks+Operation_Manual.pdf If needed I will try to find them on my network if you have no luck on the internet. regards Share this post Link to post Share on other sites
