Posted 30 Jan 2020 I am trying to create a group of data displays to show the contents of an array. The variable is from the NX PLC and the the array is defined as Short(99). In my Create Duplicate Objects window, this variable doesn't show up. I did exactly the same with a local variable inside the NA page only and it worked as expected. Does this feature only work for internal NA variables? Share this post Link to post Share on other sites
Posted 1 Feb 2020 Hi, You can use it with controller variable too, but cant use an array inside a structure. Try it with a simle array in PLC and its work. Share this post Link to post Share on other sites
