LRH095
stepper motor controle CP1E
7 posts in this topic
Hello All,
I'm a newbie to Omron programing
I have a program where I want to control a stepper motor with 1 plc output "pulse output0"
in my program I used PLS2 instruction but when I execute the instruction the motor won't rotate and the plc outputs are off, My wiring is fine, and my plc is CP1E-N40S1DR-A
MY 1st output is pulse output 0 Q100.0 and also the driver wiring with the stepper motor is good ( I did a test with siemens plc the motor does work fine ) , what could be the problem? thanks,
PLC OUPUT 0 SETTING
PLCSETTING.PNG.9e6dadc31b2a9f240681a0f6a
Capture1.PNG.13dfc5df485fb9bb0ca63c7fe48Capture2.PNG.fc086dc0c9360e72e770f680bd7Capture3.PNG.1dc95c6fd34abc48efa56fdf919
Welcome to the forum.
MOV instruction will only move 4 digits.  Use MOVL to move 8 digits.
Right now your target frequency is set to 0.
Additionally your plc has relay outputs.  It will never be able to switch at 50000 hertz.
1 person likes this
Thanks for your reply
yes I just found out that my outputs are relay type,
I changed the mov instruction to movl for the target freq and also I lowered the Frequency to 10Hz but the outputs still off, is the plc must be transistor type
to make the outputs toggle,
Edited by LRH095
High speed outputs will ONLYCP1E_Transistor_Output.thumb.JPG.1dfe65a work if the model has transistor outputs.
Thanks for your reply , so the CP1E-N40S1DR-A is relay output ,can I add a transistor output module as an expansion and use its output for pulsing?
No, expansion units cannot be used for pulse output.  Only CPU OUT 100.00,100.01,100.02 and 100.03.
Pages from W480-E1-04 CP1E Software.pdf
1 person likes this
