Posted 9 Oct 2019 Hello I'm new with GT Designer 3, I'm writing code for a GOT2107 HMI. I have a few buttons that when you press it, the LED on the switch comes on, and when depressing the switch the LED goes off. That's good, but how do I create a latch, that when the switch is pressed and depressed, the LED will stay on. and only go off after the next press and depress? The attached image is my working switch button. Regards Marinus Share this post Link to post Share on other sites
Posted 9 Oct 2019 Than look at the Action tab again and look at the Lamp part at the bottom. Also you are using the general switch for multiple actions. you can use a standard bit switch Share this post Link to post Share on other sites
