budiman
Encoder E6CP Omron to PLC Omron
20 posts in this topic
Hi All,
I really need help on connecting Encoder Omron E6CP to PLC Omron.
What PLC should i be used? Is it possible to use CP1E-N40DR-A?
Can i ask for sample program for this case for me to learn, since this encoder use 8 cable?
How is the connection diagram for Omron E6CP to CP1E?
Really need help for this case.
Honestly, i ever programmed PLC Omron for some case DI/O, AI/O, using remote IO, Modbus and etc but I'm still new to Encoder.
Thx.
Best Regards,
Budiman
budiman,
Welcome to the forum.
Do an internet search on gray code to binary plc logic.
The E6CP has a gray code output and you will need to convert that to binary for use in our plc program.
gtsuport
CJ2 plc has a GRY instruction to do this.
Hi Gtsupport & Jay Anthony,
Thx for the support and reply.
Means i cannot use CP1E and need to change to CJ2 series?
Or is it possible without GRY instructions, i just use normal ladder diagram and read the encoder data to CP1E?
If it is possible, how about the configuration? or the wiring?
Do i need to do special configuration like high speed counter, etc?
I will read the manual about this and get back here again.
Thx.
Best Regards,
Budiman Chandra
Edited by budiman
Hi Jay,
I cannot seem to download the file.
Would you mind PM to me please?
Thanks
gtsuport
Hi All,
Means without GRY command in CJ series,
I can use CP series and use to convert gray code by some sort of ladder diagram?
Please correct me if I'm wrong.
Thx.
Best Regards,
Budiman Chandra
You are correct.
I am unable to download Jay's GRAYCODE.pdf.
Guessing that is the plc logic you would need.
gtsuport
I can open the PDF file just fine.
The CP1L and CP1H processors have the GRY instruction, but not the CP1E.
Mike,
What browser and pdf viewer are you using.
I cannot get the file to download.
Thanks.
30 minutes ago, gtsuport said:
Mike,
Thanks.
Chrome and Acrobat Reader
Mike,
Loaded Chrome and Acrobat Reader this morning.
Try to download and get a  Failed - Network Error message.
Would you try to PM the Graycode.pdf please?
Thanks
Sorry Mike,
Failed again.  Not sure what the issue is.
Thanks!
Mike,
Graycode.pdf is attached.
Thanks!
GRAYCODE.pdf
Still have the same issue with the attachment.
Thanks.
Interesting... I can open it from your link also...
I can also open it from both of your link.
Really thx for the help.
