Posted 22 Sep 2019 Hello, i´m a new in omon PLC , I would learning about measuring with encoder. I have a plc cp1l and a encoder of 1000 pulses, I want make a reading of position and speed. The encoder are coupled in a roller,this roller there is the 900mm of diameter, so the conveyour move the piece under the roller. While the piece pass in the roller, the plc should make the calculins about size of piece and your speed. I would learning about how make the program, the requisition of program is make the reading about linear desplacement and speed. Remembering the encoder are acouple in roller and this roller make touch in the piece.( I have a axis with motor for pass the piece and the roller is only for measure). Please, i ned help about this,thanks Share this post Link to post Share on other sites
Posted 23 Sep 2019 W462 CP1L CPU Unit Operation Manual, Section 5 Pulse and Counter Functions will explain in detail how to wire the unit and setup for encoder operation. They even have some examples for programming. Please review this section then come back with questions. Many here will be happy to help you. Share this post Link to post Share on other sites
Posted 23 Sep 2019 (edited) Added note:- To measure speed I recommend using the PRV2(881) instruction. Just be certain to use high-speed counter 0 for your encoder input as PRV2 only works with this input. Also reference this link. Though for a CJ PLC same principles apply. Very useful! http://forums.mrplc.com/index.php?/files/file/268-cj1m-motion-and-interupts-quickstart/ Edited 23 Sep 2019 by BITS N BYTES Added info Share this post Link to post Share on other sites
Posted 23 Sep 2019 9 hours ago, IO_Rack said: O Manual de Operação da Unidade da CPU W462 CP1L, Seção 5, Funções de Pulso e Contador, explicará em detalhes como conectar a unidade e configurar a operação do codificador. Eles ainda têm alguns exemplos de programação. Revise esta seção e volte com perguntas. Muitos aqui terão prazer em ajudá-lo. Hi, thanks . I will review the program!! Share this post Link to post Share on other sites
Posted 24 Sep 2019 I made a schedule for a metal profile cutting machine. In this machine there is a driving belt that takes the piece to the saw to cut. The operator enters the screen with the size value of the part they want to cut in the saw. Then the machine takes the piece counting the size and when it reaches the desired value the belt stops and has it cut. the encoder is coupled to one of the rollers that plays the part, i'm using a plc cp1l and 1024 pulse encoder. I would like to know how I calculate the part size (linear displacement). Can I send someone the program I did to review? Does anyone have an example of this programming? Share this post Link to post Share on other sites
Posted 25 Sep 2019 Do you have the encoder wired? Do you see pulses in the PLC? Have you done any programming, (working or not working)? If so, can you post your program? Share this post Link to post Share on other sites
Posted 25 Sep 2019 Quote the encoder is coupled to one of the rollers that plays the part, What is the diameter of the roller? Diameter * 3.14 = circumference of the roller Circumerfence / 1024 = distance per pulse. Share this post Link to post Share on other sites
Posted 25 Sep 2019 He said the diameter was 900mm. That sounds very large to me.... Also, depending upon the setup of the counter, it may be counting 4:1 (quadrature), so you may need to use 4096 for the counts per rev. Turn the roller 1 time and see how many counts you see in the PLC. Share this post Link to post Share on other sites
Posted 25 Sep 2019 900 mm = 34.4 inches ? I agree with you Mike, it could be times 4 for quadrature. Share this post Link to post Share on other sites
Posted 25 Sep 2019 I'd better post the program, but I don't know how to do it here. I'm new to the forum. the roll is 90 mm sorry Share this post Link to post Share on other sites
Posted 26 Sep 2019 When you open a reply, this will be at the bottom. Click on choose files and a Windows explore window will open. Just choose the file and then push the Upload button. Share this post Link to post Share on other sites
