TiakDK
From DINT to Struct (DUT)
3 posts in this topic
Hi does anyone have an idea how to convert a DINT to a Struct containing 32 bits?
Today i convert the DINT to an Array of 32 bits then i move each bit in the array to the struct like this.
I don't like the way to do this therefore my question.
hStatusArr[0]:=DINT_TO_BITARR(iInputStatus,32); (* Load status into array *)
oStatus.bit0:= hStatusArr[0];
oStatus.bit1:= hStatusArr[1];
oStatus.bit2:= hStatusArr[2];
oStatus.bit3:= hStatusArr[3];
oStatus.bit4:= hStatusArr[4];
oStatus.bit5:= hStatusArr[5];
oStatus.bit6:= hStatusArr[6];
oStatus.bit7:= hStatusArr[7];
oStatus.bit8:= hStatusArr[8];
oStatus.bit9:= hStatusArr[9];
oStatus.bit10:= hStatusArr[10];
oStatus.bit11:= hStatusArr[11];
oStatus.bit12:= hStatusArr[12];
oStatus.bit13:= hStatusArr[13];
oStatus.bit14:= hStatusArr[14];
oStatus.bit15:= hStatusArr[15];
oStatus.bit16:= hStatusArr[16];
oStatus.bit17:= hStatusArr[17];
oStatus.bit18:= hStatusArr[18];
oStatus.bit19:= hStatusArr[19];
oStatus.bit20:= hStatusArr[20];
oStatus.bit21:= hStatusArr[21];
oStatus.bit22:= hStatusArr[22];
oStatus.bit23:= hStatusArr[23];
oStatus.bit24:= hStatusArr[24];
oStatus.bit25:= hStatusArr[25];
oStatus.bit26:= hStatusArr[26];
oStatus.bit27:= hStatusArr[27];
oStatus.bit28:= hStatusArr[28];
oStatus.bit29:= hStatusArr[29];
oStatus.bit30:= hStatusArr[30];
oStatus.bit31:= hStatusArr[31];
Hi
This is no good looking solution but it works.
DMOV(TRUE, VarDINT, K8M0);
And you must assign your struct to M0..M31
Hi GreenMan
Thanks for the example.
No it seems that ist not any good solutions for that.
I cant assign the struct to a global variable. I use it in a FB, that I need to reuse several times.
