KRS20
Micro850 CCW Panelview Help
2 posts in this topic
I have a project i have created in CCW on the Micro850 platform.
I have added a 2711R-T7T HMI to the project.
All of this works perfectly fine.
I want to add an additional HMI to the controller / project but it will not allow me.  "Only one graphic terminal is allowed in the project."
Is this a limitation of the software / series of controller? Is there a workaround?
Is the hmi connected over ethernet?
If so i have never done this before but have asked rockwell as it was a plan for an upcoming project.
The answer i got was that it shouldn't be a problem.
Because ccw only allows you to have 1 hmi at a time, try open it in a separate project and add the tags manually.
or save as the project under a different name and then create the second hmi in that separate file.
