Posted 9 July Hello everyone, I need help for the titled matter. The problem is that i am using CX programmer v 6.1 trial version 30 days. The error i am getting is PLC failed to connect. so the cable in attachment is right one? It is CN226 USB to Peripheral port cable. DIP switches are all off. Should in set them in on off state? if yes so whats the sequence? Replies will be highly appreciated Thanks Share this post Link to post Share on other sites
Posted 9 July CQM1H dip switch information is attached. Share this post Link to post Share on other sites
Posted 9 July Switch 5 On. Set Port settings to 9600, E,7,2 Share this post Link to post Share on other sites
Posted 9 July Thanks Jay Anthony & gtsuport. Is the cable shown in my post is ok? it is CN 226. Jay Anthony you said Switch 5 is on & Port Settings to 9600, E, 7, 2. So This setting is for CN 226 cable? What if i use RS232 to USB? Is there different settings for this cable? & By using RS232 to USB, am i able to online Plc & save program file to my PC? Share this post Link to post Share on other sites
Posted 9 July Yes, the CS1W-CN226 should work. USB to RS232, not all adapters works correctly. You can try to see if you adapter works. If not, I would suggest the USB CN226 cable from www.plccable.com https://www.plccable.com/omron-plc-programming-cable-usb-cs1w-cn226-cs1wcn226-usb-version/ Jeff Share this post Link to post Share on other sites
Posted 12 July Link made successfully. Now its giving message that UM Program read is protected. What's the solution for reading program? Share this post Link to post Share on other sites
Posted 12 July You will need to contact the OEM or original programmer to get the password. Share this post Link to post Share on other sites
