kurdapyu
Melsoft Series GX Develop Error
16 posts in this topic
Good day everyone.
Somebody can help me to to resolve the issues in our PLC. I am not a PLC engineer, your help will be highly appreciated.
It is showing -
Failed to open the Project file.
Possible causes: 1.The data in the project file is completely damaged; 2.The data is created by new version more than this S/W; 3.The project file does not exist.
Hopefully, somebody can help me or give instruction on how to check those possible causes.
Thank you.
Edited by kurdapyu
Which version of GX are you using ?
that's not to old. You should also check if files are read only.
If you are opening this directly from windows explorer...make sure you are opening the right file (from memory there are a .gpx and a .gpxx file) this error normally happens when you open the wrong one.
Alternativley upload your program and I can check for you.
Regards
Daniel
thank you everyone for your response.
i think i am opening the right file. because once i click the project button, there are portion for recently open program.
and when i click the file/program. it display the error "Failed to read the project file" as shown in the first photo.
Thanks again.
Edited by kurdapyu
Thanks again.
Please upload your program and I will check for you....
Regards
Daniel
1 person likes this
Version 8 doesn't tell us enough.  What is the full version number?  There's been over 115 releases of version 8.
The project may be from a newer version.  It may have files missing.  It may be tagged read only in Windows.  There's a hundred different things that it could be.
Please provide more detail on the version and PLC type.
1 person likes this
Regards
Daniel
Sir Daniel,
I think the program was still there but cannot be open. highlighted with red line is the recently open program which properly working before.
And when I open the .gps type of file it display that "failed to read the project file"
PLC is MITSUBISHI
Edited by kurdapyu
Well if you're using GX-Developer, there's about a 100% chance the PLC is Mitsubishi.  Which one?  They make quite a few.
Are there files and subdirectories in the Resource project folder?
Are these files not marked as read only?
1 person likes this
Good day.
Yes, it is MELSEC Q61P if I'm not mistaken.
Yes I think so there are files.
All files are marked as read only except for the program files.
Please see photos for reference that might help.
Thank you very much. Your help is well appreciated.
Ok you have a system Q (Q02HCPU).
Project files are for GX Developer.
I would select all the files and remove the read only checkmark and then try again.
If it still won't open maybe you can share the project so we can try.
If you want to download the update for GX Developer:
http://www.mitsubishielectric.com/fa/download/software/index.html
We do as you say but still it won't open.
Herewith is the copy of the program.
Please check if you can try to do something about it.
Thank you.
Gppw.gpj
Gppw.gps
Project.inf
ProjectDB.mdb
Gppw.gpj
Gppw.gps
Project.inf
ProjectDB.mdb
sure but Can you just zip the complete project including the resource folder and then attach it ?
As stated we need the complete program, the files you have sent are only part of the program structure, the RESOURCE folder is missing. I have managed to open the file using a substitute RESOURCE folder but obviously the program isn't correct.
Steve
