Matthew2019
Omron PLC's with Syswin3.4
10 posts in this topic
Hello, i am learning PLC programming with OMRON syswin 3.4 and before purchase cables i need to know if that works with Omron  CQM1 CPU45-V1
i read in manuals that i will be able but when i made new project in Syswin i can't see CQM1 in drop menu.
thanks in advance
Edited by Matthew2019
I don't think i have same version as you have, see attached screen shot
You have the CPM1 version.
Without a serial number to activate the software, it goes into CPM1 mode.
Hope this helps.
gtsuport
You may have a lite version (demo) you may need to talk to an omron rep to get a full version or a version of cx one
Thanks for the answers, i already contact local Omron rep asking for help.
I can get  one Omron CPM1A cpu with a peripheral cable,  i found the following adapter on internet for 40 euro.
OMRON CPM1 - CIF01 RS-232C ADAPTER INTERFACE UNIT
thanks
What is the part number of the peripheral cable?
Omron USB to RS232 adapter is part number CS1W-CIF31, expensive but it works.
Alternate that I have had good luck with is Keyspan USA-19HS.  You should be able to get this from Amazon or Ebay.
Just checked Ebay, they have a lot of CPM1A units.
You can purchase a usb cable for the CPM1A from here:
Cable
May not be the cheapest cable, but I know this one works.  Chinese cables sometimes do not.
gtsuport
Mention on the cabel sticker Omron C200H-CN222, come together with PR027 programming console.
C200H-CN222 will only work with the PRO27 programming console.
The CPM1-CIF01 works with Omron Cable C200HS-CN220-EU.
gtsuport
