Matthew2019
Analog input Omron CPM2 with Syswin 3.4
9 posts in this topic
Hello gents,
I am learning PLC programming with Omron Syswin 3.4 software and i use for this project Omron CPM2 CPU.
Someone can explain  how to program in ladder diagram a analog input with range 4mA = 0 and 9999 = 20mA. I want to storage the value in a DM1010 for example.
Thanks in advance.
Welcome to the forum.
Take a look at the SCL instruction in the programming manual.
CPM Programming Manual
gtsuport
Thanks for your advice, but i would like to do it with math and use move and divide instructions. my range is -20 celcius to 100 celsius, 0 to 9999 , 4-20mA.
i have then 9999 / 120 cenlsius = 83 per 1 celsius.
Thanks in advance
So what exactly is holding you up?
Do you know the formula? The formula is in the SCL instruction Help section, the manual that gtsuport has provided, or a google search. Try performing it in a spreadsheet first.
Edited by IO_Rack
Whats hold me is the following, how to i program the analog input to a move  in combination with other instruction? is that possible?
I dont want to use SCL .
Thanks in advance
You could use an Always On bit, or a pulse bit.
Addresses should be in the Programming Manual.
So an always on bit with a DIFU and bellow the difu contact with move. and how to determine the range?
On move i can only have the source and one destination memory right? the source then it will be 4mA? >> 0 ?
Thanks
Slope formula:
y = mx + b
Quote
You provided your answer.
9999 / 83 =120
b = -20
gtsuport
