LemmyRose
Discrete Input Module Issue on DL06 PLC
3 posts in this topic
Top 3 Best Rated Shark Vacuum Cleaners in 2020
Introduction
Shark is well known as one of the Top rated best vacuum cleaners on the market. They offer a diverse range of options to cover different cleaning needs and budget considerations.
Hence, it is not easy to determine which is the best vacuum cleaner. Depending on your needs, one model might be better compared to others.
In this review, we will have a look at three vacuum cleaners from Shark that we consider to be the best for generic uses, for pet owners and for quickly cleaning up light messes.
1. Shark APEX Upright Vacuum with DuoClean for Carpet and HardFloor Cleaning, Zero-M Anti-Hair Wrap and Powered Lift-Away with Hand Vacuum (AZ1002)
Features and benefits:
_ Dual brush roll configuration that’s capable of deep cleaning carpets and providing better cleaning for hard floors.
_ Zero-M technology actively removes tangled hair from the brush roll, preventing clogging.
_ Remove the canister to easily switch from Upright mode to Powered Lift Away mode for cleaning on stairs, high places, or duck under low furniture.
_ Utilize HEPA filter to trap 99.97% of fine dust and allergens.
_ Long 30 ft power cord provides excellent reach.
_ LED light on floor nozzle and handle provides extra visibility.
Things to keep in mind:
_ Price is on higher side.
_ Only has two onboard holder for attachments, while the vacuum comes with a set of four tools.
2. Shark Navigator Lift-Away Professional NV356E
_ Brush head is specifically designed for deep carpet cleaning and gentle hard floor cleaning. Ideal for switching between different types of flooring.
_ Remove the canister to easily switch from upright mode to lift away mode for cleaning on stairs, high places or under low furniture.
_ Utilizes HEPA filter to trap 99.97% of fine dust and allergens.
_ Long 25 ft power cord provides excellent reach.
_ Quite loud compared to other models.
➨➨➨ Picked For You: Best vacuum cleaner for home - The best vacuum in the world
3. Shark Cordless Rechargeable Floor & Carpet Sweeper
_ Much quieter than a typical vacuum.
_ The motor-powered two-speed brush roll can pick up light mess, even pet hair.
_ Maneuvers easily on hardwood floors and under furniture.
_ Extremely lightweight at just 4.25 lbs. Battery can hold a charge to cover small to medium area. The sweeper is ideal if you need to clean up light messes quickly or frequently throughout the day.
_ The sweeper might have some difficulty moving on carpet. It works best on hard floors.
_ For major debris or a heavier duty job, a vacuum cleaner will be more efficient.
Final thoughts
Three of the Shark vacuums in our Best vacuum cleaners in the world - Top 10 rated vacuum cleaner reviews are all outstanding choices. The Shark APEX is great with pet hair, the Shark Navigator Lift is a great all rounder, while the Shark Cordless Sweeper is light and affordable while still being very capable of quickly cleaning up light messes. Whichever cleaning tasks you need, giving these three a consideration will well worth your time.
Edited by LemmyRose
When you swapped the modules did you swap the wiring block? If not then it is most likely the module. If you did then inspect your wiring, especially the commons. It sounds like commons - signals swapped.
Edited by b_carlton
