Milosh
APR - OUTPUT VALUE
12 posts in this topic
Hi all.
I have APR function for linear scaling.
Sample
X0=4000, Y0=80
X1=3000, Y1=82
Which would be the output Y for X=3000?!
It should be 80.
This function returns X0 if is X<X0?!
Which PLC family?  Also, can you show the values of the control words?
D650 = #201
D651 = 4000
D653 = 80
D655 = 3000
D657 = 82
APR
control word = D650
Source word = 3000
Result word = D760
19 minutes ago, Milosh said:
D650 = #201
D651 = 4000
D653 = 80
D655 = 3000
D657 = 82
APR
control word = D650
Source word = 3000
Result word = D760
Not quite correct. Only way I could make it work is if in the APR  if X1 is greater than X0.
See attached code with OP's data.
CP1L_APR_SCALING.cxp
Edited by BITS N BYTES
Thanks a lot.
But how to convert these values to be correct. Maybe to use some NEGATE function?!
6 minutes ago, Milosh said:
Thanks a lot.
The example I posted works correctly for the values you are asking for.
Thanks a Lot. But what happens if I have floating numbers. Let say. D651 = 4000 and D653 = 80.45?
which PLC?
Floating point in APR only available on :
Single-precision floating-point data (CJ2/CS1-H/CJ1-H/CJ1M/CS1D Only)
According to APR help.
CS1H-H CPU64. I think that Ishould use NEGL instruction to negate D651 and D655, and than it would be work?
for floating point control word bit 09 needs to be set. So:
Control word:
D651 = &512
D652/3  X0 = 3000.00
D654/5 Y0 = 80.45
D656/7 X1= 4000.00
D658/9 Y1 = 82.00
Thanks a lot all.
I do the NEGL and everything seems to be ok.
