Posted 15 May 2019 What are all the possible way to fetch data from nine Omron CJ2M-CPU13 for an OEE application. Is it possible to communicate by adding an EtherNet/IP module to it. I need to connect to Kepware Server. Share this post Link to post Share on other sites
Posted 15 May 2019 @Karthikeyan_cmps Please check these link below about OMRON Ethernet drvier for KepserverEX. https://www.kepware.com/getattachment/7551f988-97df-426b-a00d-e8731a5b7607/omron-fins-ethernet-manual.pdf https://www.kepware.com/getattachment/0cc86a2f-5d20-400b-942e-ea86da321791/configuring-omron-plc-with-fins-driver.pdf Share this post Link to post Share on other sites
Posted 15 May 2019 10 hours ago, Karthikeyan_cmps said: What are all the possible way to fetch data from nine Omron CJ2M-CPU13 for an OEE application. Is it possible to communicate by adding an EtherNet/IP module to it. I need to connect to Kepware Server. Yes it is possible to add a CJ1W-EIP21 or CJ1W-ETN21 module to the CJ and get data using Kepware. As long as you have room for the module (less than 10 modules in the rack and physical space as well). Share this post Link to post Share on other sites
