Posted 13 May 2019 (edited) I get the input of an encoder and do operations based on that, for at least twenty object 'slots' at once. Program is on ladder since client needs to be able to modify it at will, but I'm using structured text functions to handle all the messy operations, since every object has properties and data, and up to twenty can be running in real time. This is a CP1L. Instead of instancing those function blocks twenty times each, I keep a single instance of them one running all the time, and output TRUE when one of those objects raises a valid comparison. In essence those FBs compare each objects' relative position to the encoder against defined points. The picture is an example of the functionality I'm needing. When one object completes the FB task, one of its flags turns ON so that it can't be used anymore. The issue is that without an input/output ST variable, this flag stays ON no matter what, and I need to reset it from outside so the cycle can begin again. The inner FB bit linked to this output stays ON since nothing inside of it makes it change. That's why I need an input/output variable. In the picture the timer would reset the bit - until the FB turns it on again - but I can't do this in this controller. Is there an elegant way to make this work? I know I could use the rising edge of the output to turn some other bit ON but that's the kind of thing I want to avoid. Edited 20 May 2019 by viman Share this post Link to post Share on other sites
Posted 20 May 2019 (edited) I figured it out. Following the previous example... I added an input that acts like a proxy to this property that I could not change. This input turns the output to FALSE when I'm done with it. Edited 20 May 2019 by viman Share this post Link to post Share on other sites
