Posted 10 May 2019 hi there, i have a problem on the data moving. here the problem. how can i write a command like : if value in d500 is in betwee 3000 to 3100 then on m1000 if between 3100 to 3150 then on m1001....... and so on. thank you very much Share this post Link to post Share on other sites
Posted 10 May 2019 Hi welcome to this forum. You can use these command in ladder programming. This will solve your task. >= D500 K3000 & <= D500 K3100 out m1000 >= D500 K3100 & <= D500 K3150 out m1001 Thanks & Regards, Areeb Share this post Link to post Share on other sites
