Rob Nelson
Micrologix 1400 ASCII String Compare Not Working!
4 posts in this topic
Hello All,
                I am in the process of installing a DPM Scanner to one of our machines.  I am trying to program an ASCII String Compare to compare the scanned part number, stored in a string as ST14:0, to a constant value stored in ST15:13.  I have used this tactic before in other applications and it has worked fine every time, except this time.  Am I doing something wrong?  Is there a setting I am not aware of?  Please see the attached image.  Thanks in advance!
Edited by Rob Nelson
That particular rung is still in edit. Note the e's on the left.
Yes, I took the snap shot offline.  Thank you.
Various possibilities: in a subroutine which isn't called, string not changed/zeroed between scans (otherwise the one shot won't trigger if scan is the same), one shot address used elsewhere.
