Posted 3 May 2019 Hi, Is it possible to play a video continously? Currently, it plays once and stops. It's for marketing purposes. Thanks in advance. Share this post Link to post Share on other sites
Posted 3 May 2019 I would imagine that you could write a script to make it repeat. This video link below shows how to write the script to play, stop and pause a video. You would just have to create a global subroutine that issues the play command and then call that subroutine by a timed event. Just set the timer to a little longer than the video and it should work. https://www.youtube.com/watch?v=JzyAtgwVKKw Share this post Link to post Share on other sites
Posted 7 May 2019 On 3/5/2019 at 0:44 PM, Michael Walsh said: I would imagine that you could write a script to make it repeat. This video link below shows how to write the script to play, stop and pause a video. You would just have to create a global subroutine that issues the play command and then call that subroutine by a timed event. Just set the timer to a little longer than the video and it should work. https://www.youtube.com/watch?v=JzyAtgwVKKw Thanks! Share this post Link to post Share on other sites
