Posted 17 Apr 2019 Does anybody know where I can get a key for the S6 pro16 console? Even a side picture would do as I can probably make one. I have the console, but without the key it's a paperweight. Share this post Link to post Share on other sites
Posted 18 Apr 2019 Watch the addressing, did this is CX-Programmer and some of the addresses don't work. LD 0.03 OR 0.04 OR 0.05 LDNOT 0.10 ORNOT 0.08 ANDLD AND 0.09 LD 0.03 AND 0.00 AND 0.01 ANDNOT 0.09 ANDNOT 0.06 LDNOT 0.03 AND 0.04 ORLD LD 0.12 AND 0.13 ORLD ANDLD LD 0.08 ANDNOT 0.07 ANDNOT 0.11 ANDNOT CNT001 OR 0.03 ANDLD ANDNOT 0.11 ANDNOT 0.09 OUT 0.12 OUT 0.13 gtsuport Share this post Link to post Share on other sites
Posted 18 Apr 2019 (edited) I am re-posting. The last ANDNOT 11 was supposed to be AND NOT 111. OMRON SEQUENCE MR PLC.pdf Here's the entire program if anybody feels ambitious. I give up! I can't translate enough of this to make a difference. OMRON PRESS PROGRAM.txt Edited 18 Apr 2019 by stickman47 Add full program listing Share this post Link to post Share on other sites
Posted 23 Apr 2019 Let me get some sleep and I will do it for you. Share this post Link to post Share on other sites
Posted 24 Apr 2019 Did you get your problem solved and are you trying to translate to CX Programmer? ? Share this post Link to post Share on other sites
Posted 2 May 2019 No, I am trying to draw the ladder based on the program list. CX is changing the addresses. My address is 111, CX makes it 1.11. Some of my references do not translate to CX. HDM does not translate in CX. I just want to understand what is here so I can make adjustments. this controller is running a small punch press. The press is not stopping at top dead center. I need to adjust something in the program to offset this difference. There are no cams and the proximity switch that is connected to the HDM terminals has no adjustment. My boss wants to rip the whole thing out and have me install a Cieco press control, but that is $5,000! Share this post Link to post Share on other sites
Posted 2 May 2019 I wrote up an example of how to replace an HDM function from an S6 in a CP1L a while back.... I have attached it here in case you need it. CTBL in CP1L for replacing HDM in S6 conversion.cxp Share this post Link to post Share on other sites
Posted 3 May 2019 I think he just needs to understand how the HDM works. He does not want to replace the S6. I am at the doctors office and will get back on it when I get home. I have got the ladder halfway done. Syswin is better for converting this one. Share this post Link to post Share on other sites
Posted 3 May 2019 Ok, then how about this: C20H HDM Instruction.pdf I know that this is for the C20H, but this should help clarify. Share this post Link to post Share on other sites
Posted 3 May 2019 (edited) Or this: Omron S6 Manual See printed page 42. gtsuport Edited 3 May 2019 by gtsuport Share this post Link to post Share on other sites
