LLIyPiK
Mitsubishi 2401 File set error Q2ASH
Hi to all!
We have a problem with starting CPU. In GX Developer we click "Diagnostics" and see Error 2401 File set Error. What causes this error?
Error code list[Error code 2401]
Applicable machine    QnA series PLC
Error code(SD0)    2401
Error message    FILE SET ERROR
Common information(SD5-12)    File name
Individual information(SD13-20)    Parameter No.
LED status(RUN)    OFF
LED status(ERROR)    Flashing
PLC operating state    Stop
Diagnostics timing    At power ON & reset
Error description & cause
File designated for the fault history file (PLC RAS parameter setting), etc., cannot be created.
Corrective action
Read out the error individual information to a peripheral device, and check/correct the drive name and file name corresponding to that information(parameter No.)
Check the memory card’s remaining memory area.
3 hours ago, LLIyPiK said:
Hi to all!
LED status(RUN)    OFF
Corrective action
Have you tried a memory format? Then download again...
Regards
Daniel
On 4/18/2019 at 3:02 PM, LLIyPiK said:
collinsd70
Thank`s, i`m trying and all is good!!
Your very welcome.
I find this normally happens for me during testing and changing of parameters, possible something is not deleted or cleared.
Regards
Daniel.
