Amsterdamstyle
Send data memory from PLC to other PLC with CX Programmer
14 posts in this topic
Hello people,
I hope someone can help me with this.
The system is connected with 8 PLC's.
I want to transfer the data memory of a PLC to another like this:
D850 from PLC2 to D900 PLC1
D850 from PLC3 to D901 PLC1
D850 from PLC4 to D902 PLC1
D850 from PLC5 to D903 PLC1
D850 from PLC6 to D904 PLC1
D850 from PLC7 to D905 PLC1
D850 from PLC8 to D906 PLC1
The data memory is an integer.
Review the FINS commands SEND and RECV.
You do not tell us what plc you are using or the network type.
gtsuport
CP1L-E
I have SEND/RECV some BOOLEAN (see picture), but no idea how to do that with data memory as integers.
Network type is Ethernet
Edited by Amsterdamstyle
You just need to you the SEND and RECV instruction, NOT the function block.
Let's assume the FINS node numbers are the same as your plc numbers.
Network number is 1.  See attached.
1 person likes this
If you are using Serial Communications between the PLC's I would use PLC Serial Links for such a small amount of exchanged data.
Requires NO programming in PLC!
Attached extract is for CJ2M PLC but available in most OMRON models.
Serial PLC Links.pdf
Thanks for the replies! How do i know what network number i have and where can i define the D200. D2001, D2002, D2003, D2004?
Sorry i'm not that experienced, working on it
Use MOV instructions.  See below.
Got it working, thanks for that. Is it possible to receive more data from the same plc?
I also want to receive D902 from PLC node 4 and write it to D702 local node.
Tried to copy and paste this but it only receive the D901
In your control word for the RECV instruction, change D300 to 2.
That is the number of words to receive.
Received data will go in words D701 and D702.
gtsuport
Hi...If you are using the Ethernet module, you might want to look at the "socket services" functions. I haven't used sockets with Omron PLCs, but it seems to be reasonably well documented. The socket services just send and receive packets of bytes, with the meaning of those bytes being up to you.If you are using the sockets services to just do some basic handshaking, I would suggest just sending some bytes with each bit corresponding to some boolean state. This is probably easier to handle at the PLC end, and it should be straightforward to pack and unpack the bits at the PC end. There should be no problem sending integer values as well.
pcb manufacturing and assembly
Edited by AraldoJanes
Send/Recv instructions are way easier to implement than socket services.  My 2 cents...
hello,
What if i am using 2 CJ2m-CPU31,
PLC1 - Unit#0 - Node #2 -
PLC2- Unit#6- Node#6
What should i put to may local and remote node of my rcv command.
Thank You in advance
Depend on which plc the RECV instruction is in and where the data is coming from.
Check the CJ2M Instruction Reference manual:  CJ2 Instruction Reference
gtsuport
Hello,
I need to send data from plc 1 to plc 2.
then send back to plc 1 one's i receive the data to reset or clear the data from plc 1.
thank you.
