tarek
CQM1H-51
i need help for programming analog moule MAB42 at  CQM1H plc to read temp from 0 to 200 C with 0mA to 20 mA
and how i make a setting to pt touch screen nt20s?
i read it and ther is a problem too cause it said that to read analog value i must set the dm6611 but there is only there 6143 dm in cpu51 of cqm1h
5cb885d0a71c9_CQM1HDM.thumb.jpg.13a53d91
I agree that the ladder won't let you put anything over D6143, but you should be able to set the value in D6611 using the memory editor shown above, or the watch window.
yes , i get it sir and really i am so thankful to you ,
and if you let me sir to send to you my simple prog code to reading temperture from 0 to 200 C using pt100 connected over a transmitter amp out from 0 ma  to 20 ma to check it out plz
omron.rar
and how i can set PT control area  and pt notify area on my touch screan NT20s-ST121
I sent you the manual above.  Here is the Chapter 3 out of the manual.  To activate the system menu, touch any two corners of the screen at the same time.
NT20S System Maintenance Menu.pdf
