Milosh
AD081 change settings via DM parameters
Hi all
Is there any document which describe how we can set let's say analog input module via DM adresses.
Which values of DM adddress corresponds  to enable analog input, to set input range, to set mean value processing etc.
Example:
If i want to enable conversion on all inputs I shold to se #FF in DM20000. But is there any doc. which explains which address and which values we should to use for
enabling, range etc.
This is also interesting for some other modules, like CTS021...
Thanks,
Miloš
W345 - Analog I/O Operation Manual
An easier method is to use CX Programmer. Double click the IO Table and Unit Setup, then double click the AD081 module. In the Parameters dialog box when you choose the setting, it will show you which memory is being used.
MrPLC_AD081.thumb.jpg.d219297e66f10ea4e5
Yeah, it's easy for binary values.
But how to know the values for Input1 input range setting, It's occupied 2 bits, which values corresponds to which ranges?
