Ninza T
Q06UDV CPU connect with Barcode reader Cognex (DM262) by MODBUS TCP(Build in Ethernet)
4 posts in this topic
Hi all,
I try to connect Q06UDV with Barcode reader of cognex over MODBUS (Build in ethernet PLC).
1. I already finish connect and success with SLMP.
2. Now i try with MODBUS.
a. I used predefined protocol. I try to read and write command to barcode but problem is only read status, can't write.
b. After read manual again i realize: i don't know address MODBUS of Mitsubishi like a picture (Schneider).
c. I read manual of QJ71MT91 then i see address like picture.
=> My question is how i can convert MODBUS address to PLC memory address, how i can read and write to Dataman ?
You need to know the Modbus adresses of the Cognex not from Mitsubishi.
In the pre-defined protocol commands you will read/write from/to Modbus adresses of the cognex. You also specify which Dataregisters will have the date to write or will receive the data
Hi Gambit, Thank for your helpful respond. But i could not find Modbus address from Cognex, i attach manual connection from cognex.
CommunicationsAndProgramming.pdf
looks like the modbus addresses are shown on page 3. Try reading holding reg 2001
