PaulKim1003
analog input configuration for SST_PB3_CLX_Profibus
Hi guys,
I have a profibus (SST_PB3_CLX) and its being used to pull data from cards (DI,DO,AI).
I am trying to add another anolog input card and I would like to use the profibus to pull data.
I have never done it thru a profibus.
My question is How can I teach the profibus that i have added another input card?
I have attached a picture of its connection parameters.
I don't know if i need to change this.
Thanks
Paul
Edited by PaulKim1003
More than likely you don't need to change the module in RSLogix, it is properly sized.
You need to program or configure the scanner to "map" the new anaolog card as a slave device to thru the scanner.
Then back in RSLogix, add your various COPs to usuable tags for your logic.
Edited by pcmccartney1
How can I program or configure the scanner to "map" the new analog card?
Thanks
I GTSed (Googled That Sh*t”) and found the manual in 10 seconds and another 15 seconds to find to software to make the changes.
