Shoaib
FX3U Analog Modules
14 posts in this topic
Dear All,
Can we use more than 8 Analog input / output modules with FX3UC?
I have 22 analog inputs, 22 analog outputs and 22 temperature inputs.
please suggest.
waiting for reply.
Thanks
I have tried config tool, but after adding No. 7 analog module, it don't show analog module in the drop down menu.
how can I use more than 8 modules wit FX3U ?
waiting for reply.
Thanks
That's correct. You can only add 8 special modules. You can add a Analog ADP on the left side if you need more .
can I use FX2N-8AD with FX3u?
or is there any PLC other than FX3U which supports more than 8 Analog modules?
Fx5U/C support's up to 16 modules on the right side and 4 on the left fx3/fx5 series analog/temp
Edited by glavanov
If you need 22/22/22 (in/out/temp) you could consider purchasing a remote IO base-node with communication and a communication module for the FX... Just install it wherever you want to and communicate with the remote node
I have checked FX5U through configurator, it also supports only 8 modules. after adding 8 analog modules, it does not shows analog modules in drop down menu.
can anyone tell me how can I use communication module to fulfillmy requirement.
waiting for reply.
Thanks
waiting for reply.
Thanks
How many discrete I/O points must you have?
Digital IOs required are  25
Then look to the configuration, I've posted above.
