Posted 8 Mar 2019 Hi everyone, Now I used Micromaster 430 controlled by a PLC. I set parameters as follows: P0010: 0 P0100: 0 P0700: 2 (using BOP-2) P0701: 1 (start) P0702:12 Terminal 3+4: Connected to Analog output of the PLC Terminal 5: connected to 24V via a relay which is controlled by the PLC DIP switch1 on (analog input1 with 0-20mA) When I turn on the relay to power to terminal 5, the inverter runs about 5 seconds, then stop automatically while terminal 5 is still powered. There are no fault and no alarm. I checked the parameter P0947 and P2110 with value 0. Especially, when I set P0700 = 1 (using Start button in Panel), the inverter runs well without stop automatically. Please give me some solutions. Share this post Link to post Share on other sites
