andyk58
Unity Pro LD Column Width?
Hi All
Been trying to change the column width of an LD Section (is this possible?) Currently there are 11 columns - I would like a few more if possible
In Tools -> Project Settings -> Program -> LD there is an option 'Number of Columns' - whatever I try and change it to it sticks at 11
At the same location there is a setting for 'Cell Width' - Single, Double, Triple which works fine
Circles again.....:-(
Regards
The logic scans top to bottom and left to right.  The 11 columns is the most you can go in modicon ladder logic.  If you need more you can go down to the next network and continue. but you have to repeat the register you are working with.
Not sure if this helps.
The number of columns do work...But it will not change your existing ladder sections. If you change and create a new section you will see the change applied. So you could just copy the logic across to the new section.
Just remember you cannot make this adjustment when online with a plc
