GERRY JERESANO
Rs232 PLC Settings
12 posts in this topic
Good Day,
Some one who can help me, the rxd command could not read the data from my load cell. I am using CP1h PLC.  Am i using the correct setting? because the led is blinking in port no 1.
Thank you,
This looks to be correct.
Your load cell, does it append a CR+LF at the end of string?
Right now you are set to read 10 characters from the load cell.  If you change the bottom node from D100 to A394, you will read all data in the serial buffer.
gtsuport
Hello,
Sorry for the late replay, I am using PT210EN. Please see the attachment.
My Setting is: 1.Continuous Data Output
                         2. 9600 Baud rate
                         3. 8data bits, even par.
                         4. CR, enable
                         5. LF, enable
That's all
Thank you,
No, you have your format wrong,  you show 8 data bits, No parity and 1 stop bit for your settings in your first post and specify 8 data bits, Even parity and 2 in your second post, so your settings in the PLC should be set to match and look like this:
Serial.jpg.8de4163cec1ed2d11d62f0a6ab025
Finally i can read my Loadcell output to my PLC.
The problem is i cannot set a data to stop my pump at certain load.
Any body can help me?
Thank you
Thank very much for your help,
Just another question, How can i convert string data or do i have to convert the DATA ( string ) in to other form of data. Because i need to stop my pump in a certain load. Just an Example i have a 100 kg load at 90 kg the pump should stop running.
Thank you in advance.
Edited by GERRY JERESANO
You will need to convert the data from ASCII to a number.
You should be able to use the HEX instruction.
Then use the converted data in a comparison instruction to stop flow.
Hope this helps.
gtsuport
Good Day,
Thank you for your support. But i don't know why HEX command doesn't response. There is no conversion output.
I have a 9.6 kg load but no conversion has been done.
What should i do?
Thank You Very Much,
I understand now. I got it in a series of trial and error, Funny but effective.
Thank you,
Hello,
Any body can answer me what happen why D103 does not convert but d104 is okay. d104 is the data of first digit + decimal of my weigh-er. D104 is the data of 2nd and 3rd digit of my weigh-er. D104 - Di= #0010, while d103 - Di= #0012.
finally i'm done, i got it. thank you..
I made my weighing scale into 2 decimal point..
Thank you.
Glad to hear you got if figured out.
gtsuport
