seabiscuit101
Square Wave Problem With Micrologix
2 posts in this topic
Hello all, this is my first post. I am using an AB Micrologix 1400 (1766-L32BXB Ser C FW 21). I was trying to generate a pulse train using the PTO instruction. I have modified PTOX funct. file. The ladder is just a simple XIO followed by PTO, (The Quick Start ladder from 1766-RM001). When I looked at the output waveform on my oscilloscope, I noticed that it wasn't a square wave. I decided to run it at several different frequencies to see how the wave form would change. At 10Hz i got a square wave. As I increased the frequency the falling edge became sloped and almost horizontal. Is this how the output should behave? The data sheet indicates a max frequency of 100kHz, but at frequencies over 150 Hz. The wave form looks like the output of SMPS.
Edited by seabiscuit101
Did you connect the dc common to the comm2 terminal? Also do you any load on your output or are you just looking at it not connected?
