tranthanhtung
Barcode Reader -- GOT
4 posts in this topic
Dear all,
I've already connected Barcode reader to input data for GOT,
But, before using Barcode reader to scan data for GOT, I need press to position where will receive data.
Example: if I want to scan data for Barcode#1 --> I need press to GD2000 --> Scan Barcode#1
Next, Press to GD2005 --> Scan Barcode#2
It's waste time press in HMI.  So, I would like do as flow: Press to GD2000 -->  Scan Barcode#1 --> (data auto fill to GD2000) --> Scan Barcode#2 --> Data auto fill to GD2005 --> ....
Who have experience about this, could you share method for me?
Thanks and Best regards!
BARCODE.GTW
Sounds like you need to write some sort of script or internal logic in the GOT.
The alternative would be to do all this in the PLC.
Do you have any recommend for bit that I need enable its to marking where receive data?
I can build it in PLC or script in HMI
Thanks so much!
@tranthanhtung If your #1 and #2 Barcode have not same length you can use compare data length from G.INPUT then place it on which data register that you need.
