Posted 21 Dec 2018 Using GS2107, FX5U. I want to change the JPG image on a screen based on if the value in a text box is either 1 or 2, any other value will also have a single default image. Is there a way to do this via script? Or is there a different way? Share this post Link to post Share on other sites
Posted 21 Dec 2018 Okay - here is something I have done. Under Environmental Setting, Screen Switching/Window. I set the device under Superimpose window to D120. I then use ladder logic to change D120 from 0, 18, 19 based on value in D121. If D121 = 1, then move 18 into D120. If D121=2 then move 19 into D120. Else move 0 into D120. 18 is the screen number for option 1. 19 is the screen number for option 2. There is no screen 0, so blank. Share this post Link to post Share on other sites
Posted 21 Dec 2018 I know you have a solution but there is a different way: You can use a "Part" - Select a word part display after creating your parts. Hopefully it is then fairly simple but let us know if you have any questions. Share this post Link to post Share on other sites
Posted 31 Dec 2018 I am exploring this option. Would I then set the Device say D1 to true in ladder logic, and on my form the part is tied to device D1. So if D1 then it would show Part1. I would like if option 1 then show part 1. If option 2 then part 2. If no option then show nothing. I only have these two options for now, but can see me using this in other applications where I want the superimpose window to show different things. Share this post Link to post Share on other sites
Posted 7 Jan 2019 It can be set to do exactly that. Word Parts Display -> Device/Style tab -> Detailed setting of parts -> indirect device The set Parts switching device to D1. Share this post Link to post Share on other sites
