Nanasakiai
Technology Module TM_Count 2x24V
3 posts in this topic
Hi ,
Am working with the Technology Module TM Count on S7-1500 but then run into some basic trouble but can't find any information about the problems so am here to ask for help.
My problems are :   -  Can't quite get the  "StatusHW" bit to TRUE ( I thought setting up all parameter will turn this bit ON but no, I also check with the Siemens example but their example didn't work neith
- How can I simulate the  single Pulse (A) for this TM Module because I don't have the actual module with me @@.
- Do Pulse (A) that feed to the Module have Address because I saw in the manual there are 2 channel to wiring the Pulse.
Am still new to this so hope you guys can help me through this rough start.
Thanks for reading!
Best regards,
76798774_tm_count_V14_SP1.zip
On 23/11/2018 at 7:16 AM, Nanasakiai said:
Hi ,
Thanks for reading!
Best regards,
As far as I can tell, you cannot simulate the Count technology module. I could never get it to work.
Hi ,
Maybe so cause the bit which tells when the device is ready never ON, and there is no way to simulate the pulse signal in hardware gate.
I will wait a little bit and hope if someone had actually did it , may came and help.
Best regards,
