Cabby
Mad42 analog setup
I am trying to setup a MAD42 analog card up in a cpu33 omron controller.   I need input 1&2 setup for 0 to 10 volt and can't get it to work. Any help is appreciated.
Please check manual at page 398 - 403 to see example setup.
https://industrial.omron.ca/en/media/W345-E1-11_CS-CJ-Series_OperManual_tcm824-112878.pdf
For Short instructions are
1. Add device at IO Table and Unit setup and select unit no.
2. Setting Input range to 0 - 10 V (and adjust scaling if you need).
3. use XFER to copy data from analog input to DM register (Ex. unit no. 0 are use CIO2005 - CIO2008 for input Ch1 to CH4).
4. Download program and parameter to PLC.
My card is unit 1 so i have set 20100 and 20101.  Where can I see raw data from the actual inputs?
For unit 1 raw data should be CIO2015 - CIO2018. It should be shown at IO Table and Unit Setup at Module parameter.
