13 posts in this topic
Hallo my name is Danu, i have a CP1E wirh CP1W-CIF11 and connect to modbus RTU device, i have done with write single coil, write single register,  read single register and read multiple register. But i try to write multiple register,  the indicator of CP1W-CIF11 is off and if i check d memory its no data. I attached my cx programmer.
Can you help me create write multiple register in cx programmer?
Thank you
AD4402-modbus edit edit edit edit edit.cxp
Thank you
First you should check that your slave device could receive modbus command 16(10 hex) or not. If it could you should use easy modbus to write them by set Function code to 10(hex) and set number to send byte for example please check thsi link at page 161
http://www.edata.omron.com.au/eData/PLCs/CP1/W461-E1-05.pdf
How to check my slave device can receive modbus command 16(10 Hex)? i use CP1E
I have checked AD4402 manual it have not information about modbus code but you can check it by connect USB to RS-485 on your computer and use this software to test Write multiple registers (function code 16)
http://www.baseblock.com/PRODUCTS/download/BBCOMTESTPRO.zip
okay i will test it with software, i will tell you about progress later
Dear
Can you give me the guide line for MODBUS RTU as VFD read/write with Omron CJ2M-CPU35 PLC using CP1W-CIF12 ?
17 minutes ago, JAHIR01717 said:
Dear
For CJ2M There are not easy Modbus as CP1E but OMRON has created function block at this link please check it
https://www.myomron.com/index.php?action=kb&article=1245
Dear Wasan,
Can you help me about professional training on OMRON MODBUS RTU,MODBUS TCP/IP, EHTERNET FINS,DEVICE NET Protocol etc and Indusoft Web Studio.If you know please help me
and I am from Bangladesh
4 hours ago, JAHIR01717 said:
Dear Wasan,
For Indusoft there are webinar for basic function at
http://www.indusoft.com/training/indusoft-jumpstart-webinar
For Omron Driver
http://www.indusoft.com/Documentation/Technical-Notes?EntryId=213&Command=Core_Download
Edited by Wasan
I done test with modbus master, and if i use function code (0x10), i can do write and read the register at the same time.
how about the ladder diagram?
This is example for writing Modbus registers for 2 register at start address 40001 for more information please check link below at page 245 - 253.
https://industrial.omron.ca/en/media/CP1E_Software_UsersManual_en_201601_W480-E1-08_tcm824-108754.pdf
This is short instructions
1. Initial data when power on.
CP1E_Modbus_01.thumb.jpg.c768c75f7b52dc0
2. Config Modbus parameter.
D1300 -> Slave Address
D1301 -> Function Code
D1302 -> Communication Data Bytes
D1303 -> Start Address
D1304 -> Number of registers written
D1305 -> Number of Bytes to send data
CP1E_Modbus_02.thumb.jpg.fd7c34e8c11afcc
3. Config data to written on Modbus register use MOVD because data is in lower byte of D1305 and upper byte in D1306 and other too.
CP1E_Modbus_03.thumb.jpg.ec968151dae469a
4. Modbus communication trigger.
CP1E_Modbus_04.thumb.jpg.3bb867e7186ef34
CP1E_Easy_Modbus.cxp
Edited by Wasan
Finally i can create write multiple register, i just follow the pdf you give me.
I want ask, how to read data (read input register and read holding register) real time or in data memory always display the real time data?
You should change function code to 03 to read data register
D1300 -> Slave Address (#01)
D1301 -> Function Code (#06)
D1302 -> Communication Data Bytes (#04)
D1304 -> Number of registers read
