2 posts in this topic
Hi my problem may have a simple solution but i cant work it out.
I need to use the Divide function but it wont let me use a decimal point in either Source A or Source B. Is there a way to use a decimal point in Logix 500 Math instructions? Im using an AB Micrologix 1400 PLC.
Can you only use math instructions with whole numbers? is there a way around this?
Thanks
James
I couldn't get it to work dividing an integer by a literal decimal number and storing in a decimal. What does work is dividing an integer by a literal and storing it in a float register or dividing an integer register by a float register and storing the result in a decimal:
ML1400_DecimalDivide.PNG.4ee81b624973944
