chrisb4748
Q03 Modbus to Nanodac
Hi,
I am having an issue with writing data to a Nanodac via modbus. I am able to read data from the Nanodac, but unable to send data across.
I am reading data from 2 different Nanodac's and want to be able to write to the both of them.
I have two different read and write addresses for the Nanodac's.
Would like some advise on how to resolve this issue.
Many Thanks.
Are you using Function code 16 -  Write multiple output registers? Sometimes if a parameter uses 32 bits you must use write using function code 16.
Is this the same type of data that you are reading?
Regards,
Garry
No, I'm using function code 05/06 for my write and 02/04 for read.
I am reading the same type of data, which the PLC can read. Its only my write function that is an issue.
Thanks
https://www.eurotherm.com/index.php?route=product/download/get&download_id=137
7 MODBUS TCP SLAVE COMMS
7.2.1 Function Codes  - MODBUS function codes 3, 4, 6, 8 and 16, defined in Figure 160, are supported and are fully described in Section 7.3, below.
Function codes 5, and 2 are not supported.
What is the actual information you are writing to the controller? If it is more than 16 bits long then use the function code 16.
Regards,
Garry
Hi,
I am only writing over 2 D reg's. D100 & D105 which is going to be less that 16 bits.
I now see that the nanodac doesn't support 2 and 5 function codes.
Thanks
