Dark
CQM1H-CPU51 Arduino Modbus RTU
6 posts in this topic
Hi!
First, sorry because bad english.
I want to measure temperatures with arduino and send the values to plc CQM1H-CPU51.
I founded the MODBUS RTU Slave Interface for CQM1-CPU4x/CQM1H CPU51/61 PLC in download section.
I am uploaded the program with dm memory.
For now i want to communicate between pc and plc to try the program, but for now no respons from plc.
I try to communicate with modbus softwares (CAS modbus scanner, Symple Modbus Master, qModMaster), but idon't have respons from plc.
Just lit one a communication led and thats it.
If someone have a functioning example for this type of communication between arduino and CQM1H please answer here.
Or someone use this Modbus rtu ladder program tell me how use it.
Thank you!
This link will take you to sample programs and explanations of the Modbus RTU protocol by Omron.
https://www.myomron.com/index.php?action=kb&article=1243
It sounds like you are using a sample program for a Modbus RTU Master, so all of the communications will be initiated by the PLC.
This means that you need to have the arduino set up to be a Modbus RTU Slave. I would start to try to communicate to the arduino using the PC modbus master software to see if you can get communications.
Here are a couple of links explaining Modbus:
https://www.rtaautomation.com/technologies/modbus-rtu/
http://www.simplymodbus.ca/FAQ.htm
Omron Modbus Map for Slaves
http://www.tri-plc.com/appnotes/modbus-map.pdf
The other way to get the information is to use the serial host link communication method. This will utilize the RS232 port on the PLC.
http://etowyzagagexod.tk/547903db83.html
https://forum.arduino.cc/index.php?topic=147526.0
Regards,
Garry
Thank You for the answer.
I trying to use CQM1H as Modbus RTU slave.
With this ladder program:
The problem with the host link communication that i need to change run mode to program mode when i want to write dm memory.
I will check all the links in your post.
Thank you!
Edited by Dark
The PLC needs to be in Monitor Mode.  Just put it in Monitor mode and leave it in Monitor mode all the time.
Thank for the answers. I will try monitor mode.
