Posted 24 Jul 2018 I've set up a range of comments as well as their Chinese Translations in separate columns in GT Designer3. How do I go about putting a selector on the HMI to switch the languages from the HMI? I've been having trouble finding out a clear way to do this. The manual didn't seem to help. When previewing the HMI, I can manually select the 2 separate languages and everything goes according to plan.Has anyone had any experience with this that could help out a bit? Share this post Link to post Share on other sites
Posted 25 Jul 2018 (edited) No problem. It is very easy. All you have to set-up the language switching device which can be a Got device or one from your PLC. Than on your HMI screen make for instance a button and use this to set this word device to 6 this means is lnaguage will switch to language 6 The language switching device can be found in your on your system Tab under enviromental settings Edited 25 Jul 2018 by Gambit 1 person likes this Share this post Link to post Share on other sites
