AlbertMessakh
Read EF82 Analog Sensor - CP1E-N30DR-A with CP1W-MAD44
5 posts in this topic
Hi Everyone..I'm having hard time to read Analog Sensor. I've try to read the manuals about expansion module, but still having hard time to understand it.
My PLC is CP1E-N30DR-A connect with Expansion CP1W-MAD44 and I'm trying to connect with pressure sensor Omron E8F2-B10C that in a certain pressure will trigger to open a Digital Valve.
is there something wrong with my setting for range? I do the setting in 4-20mA (0-5V)
I attached my Program and Picture while running, the program is only for reading the pressure sensor. the result is  -600 to +600, is there a way to earn the actual result?
I've tried Scaling and APR, But didn't understand, is there a guide/tutorial for it as well?
Cheers..
Albert
TEST.cxp
TEST.cxp
1. You're using "F" on channel 1. It should be "E" for 1-5 V input.
2. Remove the MOV D104 to 102. It clears your settings in 102.
3. Make sure you wire the signal to VIN1 and COM1 terminal
Hi Innoaloe
Thanks for the suggestion.
I Have more question though:
If i remove the MOV D104 D102, I will not get any result
If i don't remove the MOV D104 D102, I get a result but different result that appear on the LCD Sensor display
Anymore Suggestion? Or maybe I'm doing it wrong?
Thanks
I'm not sure with that though... I still don't think it's necessary to MOV data from D104 to 102. It does nothing aside from changing the settings you have already made on the P_FirstCycle call.
Just to be sure, you don't wire the IIN terminal, right? You shouldn't since it's a voltage input.
Could you give example on the difference of value? Like if the LCD shows 3000, what does it shows in CX-P?
Hi Innoaloe,
If i change it to #800E..Then nothing happen(Picture attached)
If I keep the #800 F the difference shown in the picture attached.
I wire it in Vin
Thanks
