manna
Mitsubishi Servo(Current Data Problem)
17 posts in this topic
I used Mr-j3A And B Series Mitsubishi  Servo .But I faced Encoder Current Data Problem In Both Series.I ran Positioning Mode,Jog Mode Etc. Then Show Current Data.But If Power Shut Down And Power On Again Then There was No Current Value.
Example:-
Running Time Current Data-500
Power Off And On Again Then
Current Data-0
Please Give Me A Suggestion.
Edited by manna
Are you running the system in Absoluut or incremental mode ?
Have you connected the battery in the MR-J ?
Running in Absolute Mode.
Both Battery Are  Okay.(PLC Battery And Amplifier Battery)
16 minutes ago, Gambit said:
IF you disconnect the battery of the amplifier and Reboot the MR-J3. Do you get an error ?
Which parameter(s) did you change, and to which value, to enable absolute positioning?
Did u get Any Picture from Me?.I send A Picture.
We cannot see any picture(s)...
Dear Kaare_t,
i Already Send 3 Times.Why Dont Send Yet.Show Attached Picture Failed.
Can U Give a Mail Account.here i can Send the Pic.
When Set ABS parameter is "0001" of MR Configurator-2 Software.Then Amplifier Show Alarm- 92
So you have not set ANY other parameters in the amplifier, and you're using DIO for positioning data, can you disconnect IO from the amplifier, and just use MR Configurator. Boot the amplifier and turn some revolutions, monitor the value, reboot the amplifier and see if the value is stored.
This is normally very easy, just connect the battery and set parameter: Absolute positioning is working
Thank you all who help me to fix this problem.it was my mistake.
Again Thanks Mr. Kaare_t and Mr.gambit
