petrb
Siemens S7 STL Basics
9 posts in this topic
Could someone refresh my memory how bit instructions works in STL in Siemens.
A     M      0.0
L     S5T#2S
SD    T      0
=     Q      0.0
Status of Q0.0 depends on RLO of A M0.0. If I modify a program little bit:
A     M      0.0
L     S5T#2S
SD    T      0
A     M      0.1
=     Q      0.0
Now status depends only on RLO of A M0.1, not on A M0.0 anymore. How's that?
Siemens manual says: You can terminate a Boolean bit logic string by using =/S/R, which is not this case.
**I'm NOT an STL expert but I've had to decipher it sometimes**
Investigate how the SD instruction affects the RLO. Is it true after the SD as soon as "A M0.0" is true or only after T0 times out? Or something else?
The SD instruction itself may terminate the boolean bit logic string as well.
To get Q0.0 to depend on both the timer being done and M0.1, you may need something like this:
A M  0.0
L S5T#2S
SD T  0
A T  0
A M  0.1
= Q  0.0
SD doesn't affect RLO, RLO depends only on M0.0.
I'm not really trying to program anything, I just wonder why it's behaving like this.
You must read carefully the timer instructions.
On first example the timer use an output ( can be a memory bit or an output )
When you ad the M0.1, on reality you do not assign an output to time in order to be used later on your program.
Therefore you will not involve the delayed signal from M0.0 later on other logical.
This is the reason for which on second part the Q0.0 is no more affected by M0.0.
You just create to sequences:
one which start the timer by M0.0 and the
second change the output Q0.0 according M0.1
Please, look at example on next link
http://plc.mavjuz.com/en/siemens/simatic/step5/timers.html
Edited by dekor
Adding more information and example
Thanks, but that's not what I'm asking. I know, if I want to use timer output, I have to use "A T0".
I don't understand, why in first example status of Q0.0 depends on M0.0, but suddenly what I add additional condition (A M0.1), Q0.0 is not affected by first condition (A M0.0). Please read my post more carefully.
The starting of the timer (SD T0) is an output function, this effectivley terminates the logic network (rung), the
A     M      0.1
=     Q      0.0
Is then deemed a new network (rung). Try drawing it out in ladder to visualise.
Steve
A     M      0.1
=     Q      0.0
That's what I would thought too, but then in this logic
A     M      0.0
L     S5T#2S
SD    T      0
=     Q      0.0
Q0.0 should be always on, but it is not.
Edited by petrb
Alright, if I try to draw this logic in LAD, it doesn't allow me and get error msg "The coil/assignment requires a preceding boolean logic operation", but in STL I can do it.
Your STL would equate to this in ladder
Steve
