nbourg8
Hundreds of Discrete Alarms - Simplest method?
7 posts in this topic
Good morning all!
I'm just getting into this world of controls and automation and need a way to simplify my life when it comes to discrete alarms. I do not care to separate them by tag so long as I can create a personalized for each bit/alarm triggered.
  1. What is the best way to list hundreds of alarms in a single tag?
  2. Can we make use of a struct data type? If so, what would this look like?
I understand I can use something like a tag of data type word, such as "Faults" MW100 and then reference M101.0, M101.1... M100.0, M100.1 (notice the order), but this only allows me 16 total discretes per tag.  Sometimes I'll have more alarms than 16 and sometimes way less. I'd rather not seperate them in this manner if I can avoid it.
Your assistance is much appreciated!
[edit] Siemens TIA and WinCC v15
Edited by nbourg8
Add more alarm words
Alarm word 1 - MW100
Alarm word 2 - MW101
Alarm word 3 - MW102
Just add as many you need
Over writting of address !!!
I think you mean -
Alarm Word 1 = MW100
Alarm Word 2 = MW 102
Alarm Word 3 = MW104
Or use a Data Block.
Could you explain this a little more.  I understand the importance of data blocks with regards to their involvement in function blocks and holding information, but not sure how I would structure the DB to hold ALL of the alarms?
In the attached screenshots, I have an old program from a previous job where they used a DB like you are suggesting.  I'd like to replicate it since the WinCC call seems to be farely straight forward too.
How is this done in S7 v15?
Edited by nbourg8
I think you mean -
I stand corrected, sorry  ;)
Sorry, currently working on a Mitsubishi project...
I had the same problem recently swapping from Omron to S7 - still fresh in my mind.
:dance:
You may consider to use Array in your case.
First, arrange your alarm into few categories. Assume now I have 4 categories and they have different number of alarm,
category 1: 30;
category 2: 45;
category 3: 50;
category 4: 25;
Second, create 4 array of bits based on number of alarm bit in that category:
category 1: ARRAY [0..29] OF BOOL;
category 2: ARRAY [0..44] OF BOOL;
category 3: ARRAY [0..49] OF BOOL;
category 4: ARRAY [0..24] OF BOOL;
Third, you can map the alarm bit into the dedicated alarm bit by using Ladder diagram or structure text or other language. Assume the array is under DB101.
DB101.DBX 0.0 := Emergncy_Stop_Alarm;  (*Structure Text example*)
I'm using DB address (DB101.DBX 0.0) here but if you assign a name in your program, you can use the name to call.
Lastly, wish my idea could help you.
