saruans
array set zero
Hello,
Maybe somebody know how make all array make zero. My array is DATAS: ARRAY[1..15, 1..6] OF INT;
I tried it
sustojimas.jpg.dee720eecd27e259d92f11b09
But it don't help me.
Edited by saruans
Hi,
Maybe you could make a FB with a loop. Here is an example to reset an array of bool. You just need and index and a bool as the conditon of the reset.
5ad9b8339f3e6_BoucleRAZarrayofbool.png.6
JC
I tried to use your advice and wrote FB with this code picture
arrays.jpg.fe1ec5a0f9cd0dd77484547fcfb87
I got error
arraysMistake.jpg.033fdaa5cb7bbd460180da
Could somebody  say to me how solve this problem?
I am not familiar with this platform but ...
loop ranges do match array dimensions.
is this perhaps case sensitive? I see that array declaration starts with upper case...  and why is the purpose of IF statement? But more importantly, passing parameters seem to be wrong - you are declaring is as VAR_INPUT (ByValue) but for this to be useful, it must be declared as VAR_IN_OUT (ByReference).
example posted by acpi is using proper form...
I find my mistake. It was masyvas[y,i]=0; need to do masyvas[y,i]:=0; Now I want simplify the main code. My Fb block show now that:
arrays.jpg.7229ad27d79c909e86dc32eed2dfc
If I write that:
arraysMistake.jpg.52645f35403c3f53879ae9
code working well. when have Input is true, when reset array, but I want to do that:
arraysMistake.jpg.cd96afe8f4a28b7941e7ff
Now problem with top picture, that I have input kuku false, but I wrote something to array DATAS,  so immediately reset DATAS. Somebody have advice how solve this problem and update my FB code?
fb block text format:
IF Leidimas THEN
    Masyvas1:=Masyvas;
    FOR i:=1 TO 6 BY 1 DO
        FOR y:=1 TO 15 BY 1 DO
            IF(masyvas1[y,i]<>0) THEN
                masyvas1[y,i]:=0;
            END_IF
        END_FOR
    END_FOR
reset:=Masyvas1;
done:=TRUE;
    IF done THEN
    reset:=Masyvas1;
    END_IF
ELSE
    i:=1;
    y:=1;
    done:= FALSE;
END_IF
Edited by saruans
that is because you did not use IN_OUT transfer as suggested
