noias2000
C200HW-MC402-E help
6 posts in this topic
Hi There i need your help here pls
i have one c200hw-mc402-e and i try to connect with a cs1g-cpu44h i cant realise how connect this 2 .
can you please write one simple program to connect the cpu and this card becouse i try to connect with motion perfect and i cant connect the card have 2 Flashing liths the run and disable.
this is the error
One of the following errors occurred in the configuration of MC Unit and CPU Unit: Illegal unit number Unit number duplication Cyclic initial error Unit number setting error
the unit is 0
and for the Operation Manua i cant realise how to comunicate with the card
can someone plz help
Edited by noias2000
Edit cpu model
Welcome to the forum.
You will need to use CX-Motion to program the MC402.
Motion Perfect I believe is for the Trajexia motion controller.
i have tried but the cx-motion dont have this card
Sorry my mistake is a cs1g— cpu44
Unit number duplication means you have another card (which maybe different than MC402) that uses same Unit Number as your MC402.
In this case check whether other card is set to Unit No 0 as well. Sometimes a card may take 2 unit no. space. I don't remember how much MC402 takes, but maybe it uses 2, so you cannot have other cards set to Unit No 0 and 1.
Check your IO Table in CX-Programmer first to confirm the unit addressing. If everything okay then you can move on to Motion Perfect
